Hugh: Luckily(-sort of), the temperature sensor will be near a north-facing wall which doesn't get any direct sun to speak of until near sunset so I'm hoping that'll be ok. The main downside is that it's going to have to be reasonably close to the wall (about 10" at best). I'll be relying on the almost perpetual breeze to keep the air changing. The humidity sensor seems to climb to well into the high 90's too easily anyway so I'm not convinced it's a very meaningful reading (that's with the "full blown"
Peter Anderson code).
geoff07: Serial is a good idea. I'll have to give that some thought. The main outdoor box will have all the outdoor sensors feeding into it and it will have a 433 MHz wireless transmitter to the indoor box which will house an LCD display and a pressure sensor (if it ever arrives!). Two transmitters may cause a problem unless I synchronize them.
The wireless is on trial at the moment (with the Picaxe "Manchester coding " chips) and, so far, I've had about 6 days out of a fully charged 7AH 12 volt lead acid battery with the transmitter sending every second. So I'm hopeful a solar panel will keep it charged - eventually - if I drop it down to about once every 30 seconds.
If I'm careful about screening, there's no reason that I couldn't power the remote temperature/humidity Picaxe along the serial cable that's sending the data back...
All good fun and plenty of options
John.
