scanning multiple input pins
sghioto
Lets say I have a Picaxe chip with 15 seperate inputs. All input pins will be pulled high through pullup resistors. I want to scan all inputs of course and each input that goes low will "gosub" some routine. I know I can use "if pin0 = 0 then gosub routine" and so on for each input, but is there a more efficient way to do this?
Steve G
BCJKiwi
Let b1=pins
reads status of input port into b1
pins is not listed as a command in the manual but is discussed on page 13 and following of Manual2.
However this appears only to be useful for the standard input port(s). There are some variations like
Let b1=pinsB
for the 28X1
moxhamj
How about
let b0=pins
select case b0
case 1
gosub xxx
case 2
gosub xxx
case 4
case 8
gosub xxx
endselect
But this only works if only one pin is high at any time. If the two least sig bits were high at the same time that would correspond to number 3 which wouldn't match anything. If more than one pin is high then you need to test individual bits
let b0=pins
if bit0=1 then
gosub xxx
if bit1=1 then
gosub yyy
What are you doing with the input data? Sometimes there are other cunning optimisations.
sghioto
Well I'm not doing anything with the input data. Actually this was a question on another forum and after over 150 views and not a single response I was curious myself how the code might be optimized. In this case I'll assume only one input is low at any given time.
Steve G
Presuming that we are also wishing to look for multiple key presses then to identify which of the 65536 permutations use:
main: PEEK $07,b5 ; equivalent to "b0 = portc pin"
      w1 =b5*256+ pins
      ON w1 GOSUB a0,a1,a2,a3,a4,a5,a6,a7,a8,a9,a10,a11,a12,a13,a14,a15 ; 65536 options :-))))
      GOTO main
a15:b5 = b5 + 1  ; commands here is just a dummy line for each destination for gosub
a14:b5 = b5 + 1
a13:b5 = b5 + 1
a12:b5 = b5 + 1
a11:b5 = b5 + 1
a10:b5 = b5 + 1
a9:b5 = b5 + 1
a8:b5 = b5 + 1
a7:b5 = b5 + 1
a6:b5 = b5 + 1
a5:b5 = b5 + 1
a4:b5 = b5 + 1
a3:b5 = b5 + 1
a2:b5 = b5 + 1
a1:b5 = b5 + 1
a0: b5 = b5
and if you only allow one pin at a time to be activated then use:
main: PEEK $07,b0 ; equivalent to "b0 = portc pin"
      w3 =b0*256+ pins
      b3 = 0
for   b1 = 1 to 16
      b2 = w3 AND 1
      if b2 = 1 then
      b3 = b1
      w3=w3>>1
      next b1
      on b3 gosub op0, op1, op2, ...... ,opt16
Assuming you call the same routine for all pins going low ...
w0 = ? ' Read 16-bits of input pins
For b4 = 0 To 15
  If bit0 = 0 Then : Gosub MySub : End If
  w0 = w0 / 2
Next
The 'MySub' routine knows which pin it was which went low because pin number is held in 'b4'.
If you wanted a bit mask which showed which bit it was then that's quite easy to add as well ...
w1 = $001
For b4 = 0 To 15
  w0 = w0 / 2
  w1 = w1 * 2
Next
If you didn't want to dedicate 'w0' / 'bit0' to holding pins then ...
w6 = ? ' Read 16-bits of input pins
For b4 = 15 To 0 Step -1
  If w6 < $8000 Then : Gosub MySub : End If
  w0 = w0 * 2
Next
To avoid having to go thru a for next loop 16 times:
if b3 = 0 no input was active otherwise you have a value 1 to 16 equating to bit/pin pressed
       w3 =b0*256+ pins
       b1 = 1
       do b2 = w3 AND 1
          if b2 = 1 then
            b3 = b1
          b1 = b1+1
          w3 = w3 >> 1
       loop until b3>0 OR w3=0
