SAA1064 7 segment code example
ptribbey
I recently purchased a 4 place 7 segment display. It uses the popular saa1064 to drive the 7 segs.
Looking at this post preview, all the tabs are messed up? I don't know why that is?
Anyway, this works good for my battery monitoring app.
Thanks for looking.
Paul
; ***** Super Duper Header File  *****
;    Filename:		SAA1064
;    Date:			03142013
;    File Version: 	1.1
;    Written by: 		Paul Tribbey
;    Function:		7 seg driver
;    Last Revision:
;    Target PICAXE:	20M2
symbol thousands =	b0
symbol hundreds =		b1
symbol tens =		b2
symbol ones =		b3
symbol seg7input = 	w2
symbol SAA1064 =    	%01110000						'SAA1064 i2c address
symbol SAA1064ctrl =	%01110111						'SAA1064 display control byte - $70=all current, $07=dynamic, not blanked.
											'See SAA1064 datasheet on google if needed.
Main:
readadc10 C.1,seg7input								'read an analog value - a voltmeter maybe.
seg7input = seg7input *48/10							'approximation for 0 to 5V.
call seg7
seg7:											'SAA1064 output subroutine. data loaded in seg7input.
hi2csetup i2cmaster, SAA1064, i2cslow, i2cbyte				'make sure i2c is pointing at SAA1064.
hi2cout 0, (SAA1064ctrl)							'setup the SAA1064.
bintoascii seg7input, thousands, thousands, hundreds, tens, ones 	'the first thousands is not used but has to be there.
thousands=thousands - 48							'$48 is acii "0" so point to 63.
lookup thousands,(63,6,91,79,102,109,125,7,127,111),thousands	'7 segment digits 0 to 9.
hundreds=hundreds - 48
lookup hundreds,(63,6,91,79,102,109,125,7,127,111),hundreds
tens=tens - 48
lookup tens,(63,6,91,79,102,109,125,7,127,111),tens
ones=ones - 48
lookup ones,(63,6,91,79,102,109,125,7,127,111),ones
If thousands=63 then								'blanks left digits if zero.
  thousands=0
  if hundreds=63 then
    hundreds=0
    if tens=63 then
      tens=0
endif										'end zero blanking.
hi2cout 1,(thousands,hundreds,tens,ones)					'output to 7 segment.
pause 100										'helps stabilize display.
If you change the code for the zero blanking to the follwoing, it can be done with less program space and when pasrt of a larger program will improve the speed as there is no point testing hundres and tens if the thousands is not a zero value:
  thousands=0
  if hundreds=63 then
    hundreds=0
    if tens=63 then
      tens=0
