I am trying to read in GPS (GPRMC) data from a WD-G-ZX4120 GPS module. The device outputs RS232 at 9600baud and I am trying to read this on an 18X overclocked at 8MHz and reading in at 4800baud which i think should work out OK.
The code all seems to be working fine up to the point where it is looking for the "$GPRMC" header and then does not seem to proceed.
As you may gather i am on a bit of a learning curve having not done this before so please excuse my simple questions.
Firstly do I need to interface with an RS232 converter (MAX232?) to allow the picaxe to read RS232 levels? From what i've read i didn't thing this was needed but i'm not sure.
Also if i dont need to convert levels to be read can anyone see any obvious issues with my code that would prevent it working?
Cheers in advance,
Darryl
'Program to read in GPS serial data using overclocking to correct baud rate
'Assign input pin for GPS data and unit reset
symbol GPS_IN = 0
symbol GPS_reset = 5
'Assign Variables
symbol Lat1 = w0 'b0,b1
symbol Lat2 = w1 'b2,b3
symbol ns = b4 'w2
symbol ew = b5 'w2
symbol Lon1 = w3 'b6,b7
symbol Lon2 = w4 'b8,b9
' reset GPS receiver (needed on every startup)
High GPS_reset
Low GPS_reset
Pause 100
High GPS_reset
'Aquire data from serial stream
For b10 = 1 to 40
getgrmc:
setfreq m8 'Increase clock frequency to 8MHz to get 9600baud serial from GPS
Sertxd ("readinggps") 'diagnostic
serin GPS_IN, N4800, ("$GPRMC"),w0,w0,w0,Lat1,Lat1,Lat2,ns,Lon1,Lon2,ew 'read data by $GPRMC data format
Sertxd ("havereadgps") ' diagnostic
setfreq m4 'Return clock freq to normal 4MHz
'write contents of variables to Terminal emulator
Sertxd (#w0,44,#w1,44,w2,44,#w3,44,#b8,44,#b9,44,#w5,44,#w6,10) '44 is ascii "comma", 10 is ascii "return"
Pause 5000
Next b10
End
Cheers in advance,
Darryl
symbol GPS_IN = 0
'Assign Variables
symbol ns = b4 'w2
symbol ew = b5 'w2
High GPS_reset
Low GPS_reset
Pause 100
High GPS_reset
For b10 = 1 to 40
getgrmc:
Pause 5000
Next b10
End
