Robot random decisions
tesladude
I have a robot that simply changes direction when the ir sensor or preasure switches are hit, meaning it has found an obsticle, I want to know how I can have it do random things.
I need to be able to give a random value to a variable, then set a few if statments such as
If b0< 10 turn right
If b0> 20 turn left
If b0< 20 and b0>10 turn around.
How can I give a #cap on the random value which is set?
...or is it between 0 and 7...?
Bill.b
This is part of the code for my robot, In roam mode the bot will change direction at random 'time' and ' direction' Left or right.
this is only sample code as most of the functions are not inclued. It will give you some posibilities as to how you program your robot.
#slot 0
#picaxe 40X2
Setfreq M8
#No_Data
#No_Table
DisableBod
pause 100
symbol ModeSw 		= 11		'Mode switch analogue input
symbol Mode			= b0
symbol Counter   		= B2		'counter
symbol Counter1   	= B3
symbol counter2		= b6
symbol LeftREV		= b10		'Left motor rev counter variable
symbol RightREV		= b11		'Right motor rev counter variable
symbol REVCount		= w6
symbol LeftWallDet	= 23		'analog input from Interrupt detector
symbol RightWallDet	= 13		'analog input from Interrupt detector
symbol Reverse_Range	= b16
symbol Randirection	= b17
symbol directionselect 	= b4
symbol RevLatch		= b5
symbol deadband 		= b18
symbol randomhigh 	= b26					'random number high byte
symbol randomlow 		= b27
symbol CMPEnter		= b14
symbol CMPNline		= b15
symbol LeftDistance	= b20
symbol RightDistance	= b22
symbol CMPHundred		= b50
symbol CMPtens		= b51
symbol CMPUnits		= b52
symbol CMPdp		= b53
symbol CMPtenth		= b54
symbol CMPSum		= B55
symbol ModeSel 		= w12		'Mode switch variable
symbol Randnum		= w13
Symbol range            = w14
symbol randelay 		= w15
symbol templeftPath	= w16
symbol tempRange		= w17
symbol temprightPath	= w18
Symbol leftPath         = w19      	'Obstruction value on left side
Symbol rightPath        = w20       'Obstruction value on Right side
symbol ObjectRight	= w21		'Obstruction distance on Right side
Symbol Rrange           = w22
symbol ObjectLeft		= w23		'Obstruction distance on Left side
symbol edgedata		= w24
Symbol trig 		= A.6		'Head Scanner SRF005
Symbol Rtrig 		= A.7		'Rear Scanner SRF005
symbol TrigLeft		= A.3		'Left Front Scanner SRF005
symbol TrigRight		= A.5		'Right Front Scanner SRF005
Symbol SERVOH           = b.0
symbol M1FWD		= D.7		'Motor 1 Froward output
symbol M1REV		= D.6		'Motor 1 Reverse output
Symbol M2FWD		= D.5		'Motor 2 Froward output
symbol RGB2			= D.2		'RGB LED Bit 2
Symbol M2REV		= D.4		'Motor 2 Reverse output
symbol OLED			= C.0		'serial output to OLED display
Symbol M1PWM		= C.2		'Motor 1 Speed (PWM) output
Symbol CompassSerialIn	= C.1		'Serial input from compass
symbol RRevIn		= pinc.5	'motor 1 Speed Detector
symbol LRevIn		= pinc.6	'motor 2 Speed Detector
symbol Overload		= pinc.7	'motor Overload input
symbol Select1		= pinb.1
Symbol SERVOLeft 		= 150
Symbol SERVORight 	= 450
Symbol SERVOCent 		= 280
symbol cmpbaud		= t9600	'SET SERIAL OUTPUT baud rate for GY-26
symbol Baud			= N2400	'Set serial output baud rate for OLED
symbol vshortdelay 	= 150
symbol shortdelay 	= 450
symbol middelay 		= 2000
symbol longdelay 		= 2200
Roam:
'	gosub DistanceMessure		'check if forward direction is clear
	 serout OLED,Baud,(254,128)
 	 serout OLED,Baud,("    Roaming    " )
	gosub FWDFast				'set bot to forward direction
	pause randelay
      counter1 = counter1 + 1			'get a random delay value for turn counter then add 1 to count
	if Counter1 = 10 then
		gosub randomselect
		if Randirection =1 then
			LeftREV = 7
	 		gosub turnleft
	 		LeftREV = 7
	 		gosub turnright
	 	endif	'
	  	gosub FWDFast			'turn bot to the left when counter = 10
	if Counter1 = 20 then			'turn bot to the right when counter = 20
		gosub randomselect
	  	counter1 = 0
	  		LeftREV = 7			' reset counter
	 		gosub turnright
	 		LeftREV = 7
	 		gosub turnleft
	 	gosub FWDFast
	goto Roam
randomselect:
	' generate random time delays when in micro control
	' w3 contains the random number gerated each time this
	' routine is called and randelay is set to value determine by the
	' value in Randnum
	random Randnum
	if randomlow > 200 then
		let randelay = 600
		let Randirection =1
	if randomlow > 150 then
		let randelay=500
	if randomlow > 100 then
		let randelay=400
		let Randirection =0
	if randomlow > 75 then
		let randelay=200
		let Randirection =1
	if randomlow > 50 then
		let randelay=100
		let Randirection =0
	let randelay=50
	let Randirection =1
TurnLeft:
	b6 =5
'	gosub rgbcolour
	Revcount = 0
	 serout OLED,Baud,(254,192)
 	 serout OLED,Baud,(" Turning Left  " )
		High M1PWM
		high M1FWD
		low M1Rev
		Low M2FWD
		Low M2REV
	do						' Count Wheel rotations 7 pulses = approx 90Deg rotation
		do : loop until rRevIn = 0
		do : loop until rRevIn = 1
		RevCount = RevCount + 1
	loop until RevCount >= 7
	Revcount = 0
TurnRight:
	b6 =6
'	gosub rgbcolour
	Revcount = 0
 	serout OLED,Baud,(" Turning Right " )
		High M1PWM
		Low M1FWD
		low M1Rev
		High M2FWD
		Low M2REV
		do : loop until lRevIn = 0
		do : loop until lRevIn = 1
	Revcount = 0
	Return
FwdFast:
	b6 =1
'	gosub rgbcolour
 	serout OLED,Baud,("   Forward    " )
	High M1PWM
	high M1FWD
	low M1Rev
	High M2FWD
	Low M2REV
	Return
BackFast:
	b6 =7
'	gosub rgbcolour
	serout OLED,Baud,("  Reversing   " )
	High M1PWM
	high M1REV
	low M1FWD
	High M2REV
	Low M2FWD
	for b6 = 1 to 10				'When reverse is called, first check if reverse diredtion is clear. (check 10 times)
		pulsout Rtrig,2        		' produces about 20uS pulse (must be minimum of 10uS)
   		pulsin Rtrig,1,Rrange  		' measures the range in 10uS steps
    		pause 10               		' SRF04 mandatory 10mS recharge period after ranging completes
    		let Rrange = Rrange * 10 /58/2
    		if Rrange < 20 then
    			exit				' if obstical is detected
    		pause 100
    	next b6
	Return
StopM:
	b6 =8
'	gosub rgbcolour
	serout OLED,Baud,("    Stopped     " )
	Low M1PWM
	Low M1REV
	low M1FWD
	Low M2REV
	Low M2FWD
	Return
TurnAround:
	 pause 10
 	 serout OLED,Baud,("  Turning Round  " )
		High M1PWM
		Low M1FWD
		high M1Rev
		High M2FWD
		Low M2REV
		do : loop until RRevIn =0
		do : loop until RRevIn = 1
	loop until RevCount >= 12
	Return
Bill
lbenson
Search the forum to find out ways to get numbers which are more random rather than less random. Once you choose your method, seed the picaxe basic random number generator:
symbol wRandomValue=w13
symbol cRandomValue = 48611 ' a large prime; results will be fairly random, but will repeat with power cycling
' perhaps multiply by the timer variable to get more random results (assuming that
' in your case obstacle detection will provide timing randomization
wRandomValue=cRandomValue
random wRandomValue
Then decide how many different results (actions) you want to have. If they are all equally likely then you can just get the remainder (picaxe operator "//") of dividing your random number by the number of actions (say, for this example, 3 actions).
  random wRandomValue
  b1 = wRandomValue * timer // 3  ' b1 will hold the value 0, 1, or 2
  select b1
    case 0
     ' here goes the code to turn right
    case 1
     ' here goes the code to turn around
    case 2
     ' here goes the code to turn left
  endselect
  ' here goes the rest of your code
  pause 10000  ' pause 10 seconds (or whatever you're going to do before the next random decision)
