Hello PICsters,
This Christmas my young bloke received a small robot called an "Escape" from who else, but Santa Claus. It comes in kit form here in Australia and seems to be well documented. However, the kit appears to use a "once only"(?) preprogrammed 78P156ELP 18 pin chip manufactured by a company called ELAN. Is there such a thing.... a once only PIC?
Not being around the PICAXE and PIC chips in general for very long. It appears that the PICAXE-18X could possibly replace this preprogrammed 18 pin chip? The preprogrammed chip uses pin 4 for the RESET, pin 5 & 14 for VSS and VDD, a 4Mhz. crystal is on pin 15 & 16. Other pins seem to be pin for pin for the I/O. Maybe this is just a coincidence that the pins are the same? Or maybe there is some sort of industry standard for an 18 pin PIC?
Why change it out? I think my son and I would have much more enjoyment by building the robot, programming it and debugging it. Rather then just building it, letting it run around the room for a while with the preprogrammed chip installed and then putting it up on the wardrobe shelf to die a slow death.
Has anyone hacked this kit and replaced the 78P156 for a PICAXE-18X chip? Is it possible?
EXTRA: Wife asked me if the robot can push the vacuum cleaner!
