RF serial and NKM2401
manie
Hope everyone has a wonderful year...... two questions...
1. Using two chips and RF serial with N2400_8 baud on one board. Do I still fit 1N4148 diodes but with the cathode pointing to the Picaxe and a 10K pull down resistor ??
2. Can the NKM2401 handle idle low (N2400) input/output ?
example:
                       <---1N4148----- NKM2401-------Rf receiver
           Picaxe 20x2 <---1N4148-------Picaxe 20x2
           serin       !                Serout
                      10K
                      Gnd
Edit
The serout is under the 2nd Picaxe, the text moves...
I am using Dorji 887Rx and 888Tx units in a multi to multi system.
I took the liberty of adding [code][/code] tags and spaces to your diagram. Let us know if the circuit is not as you intended it.
The NKM2401 uses idle-low, active-high, Nxxxx protocol so you need diode mixing and a pull-down as shown.
manie
Thanks Hippy
It is exactly as I wanted. The chicken coop controller is growing still, now using separate units to do the work.
Thanks for the input.
