It depends on how RevEd configured the chip ... the reset pin is just another pin on the PIC itself (although it's INPUT ONLY)... but if the CONFIG3 bit is set so that it's only function is MCLR, then that's all it is, a reset. But, if they have it configured to treat RE3 as an input, and the PICAXE firmware is polling that input and issuing a software reset, then I'd suspect you could probably do something with it via special registers. Maybe even turning it into a weak output via the weak pull-up resistor register.Is there anything else you can do with the reset button pin?
