This is the Virgin Media "V Box", a cable TV unit which finds its way onto the UK second hand market in quite a few places. With 7-seg displays ( decimal points plus colon ), 3 x LED's above 7-seg, Red/Green LED 'power switch', IR receiver, 6 push buttons, plus nice looking IMO, it may be of interest to others who want to hack-a-box to put PICAXE projects in.
Not finished reverse engineering but here's the details so far, and it's looking good ...
Officially the Samsung 2110c.
Lightweight aluminium with plastic front panel. All relatively easy to drill. Raised base should let PCB / vero-board mount nicely without bolt tops scratching surfaces..
Disconnect power, leave to stand to drain capacitors. Take care, don't open the box if not competent. All at your own risk.
The three security screws on the back are a pain to drill out ( not my finest dismantling but no visible damage when on the shelf ). Recommend finding a correct 'screwdriver'. They are Allen key style but with a raised central dimple.
The PSU connects via flying wire 'ribbon cable' can be cut and soldered. Seems to be always on, the "NOT" connection being "not connected" rather than a standby or other signal. So that's likely a nice 3V3, 5V, 5V7 and 12V source. Not sure of current rating though. 0V connects direct to the chassis. Figure-8 two-wire mains input, no earth. There are a number of PSU variants apparently.
Re-use the power supply entirely at your own risk
Front panel connects via 20-way ribbon cable, pull to detach. Socket on front panel PCB looks easy enough to solder flying leads to. Uses 0V and 5V.
The front panel 7-segments controlled by an I2C SAA1064T so that's easy. The LED's driven by transistors, equally easy hopefully - still to find the standby connections. IR receiver across 0V/5V with separate signal connection, again easy. The switches seem to use 74HC164D / 74HC1640 (?) and the circuit there's a bit weird so more work to do. Also a mysterious and minuscule SMT "U4" with no idea what that it is or for.
For rear panel connections, I'd go with screwing some thickish plastic on, mount to that, tin-snip holes where the chassis gets in the way.
More info, pinouts and software examples as it evolves. The aim is to get the whole front panel usable without anything beyond replacing the ribbon cable.
