A bunch of mains power electric heaters is no use to discharge a lot of power if the source voltage is low (12V, 24V 50V...)
If thats what you have, get a DC/AC inverter (or 2) of suitable power rating, to drive the heater(s). Cheap modified sinewave ones would be ideal, and by their lower conversion efficiency, inherently consume more power
One drawback of large loads at low voltage, is high currents and corresponding large cable size needed. Beware of burning out cables and causing a fire.
Another suggestion is to get some second hand hot water cylinders, heat lots of water and set up a free shower booth for the neighborhood! Or maybe a heated pool.
