AndyGadget
Is this a known bug? Will explore and post more details if not.
Using single quote at start of each data statement of a block works fine.
Using #rem and #endrem (in lower case) to ignore block of data causes syntax errors further down program.
Using PE 5.5.5.
*** FINAL EDIT ***
If I pass the original code through a forum post and reload into PE it passes syntax checking so unable to confirm the problem - Possibly related to a spurious invisible character? Anyway, PE6 is on the way so it'll soon be irrelevant
Using PE 5.5.5.
*** FINAL EDIT ***
