I was creating and testing a very reliable infrared morse-pulse system, which is also flexible.
At this time, I created a master-slave format of my bi-directional protocol. It works just like the I2C protocol, but the data is sent via IR. So, I would call this 'I2R'.
I've thoroughly tested this in picaxe VSM. If you encounter any problems using this, then notify me in this thread.
Morse pulse master.bas
Morse pulse slaves.bas
edit1: This is not really good for sequential writes incase one datum gets written to the slave EEPROM, and then again on the next address.
To test this system, then add the below code between the 'setfreq m8' and 'sendvar0:' in the master program, replacing the code already there.
Unfortunately, I can't download my full connection diagram because it was too big, so Ive made a version that only shows the infared junction
Debugging code for picaxe master.bas (placed between the 'setfreq m8' and 'sendvar0:', replacing the starter code already there.):
The terminal data should look like this: (repeats every 15 seconds)
symbol ad0=bit8 'variables
symbol ad1=bit9
symbol ad2=bit10
symbol ad3=bit11
symbol ad4=bit12
symbol ad5=bit13
symbol ad6=bit14
symbol ad7=bit15
symbol rw=b4
symbol adres=b1
symbol plv=w3
symbol iredout=0 'pins
symbol iredin=pin0
symbol iredin1=0
symbol hitime=100 'settings
symbol lotime=50 'half of the hi-time
symbol midtime=75 '150% (1.5) of low-time
symbol xhitime=200 'double of hi-time
symbol adresbits=4 'number of address bits
setfreq m8 'required for fast operation
'whatever you have...
rw=? '0=read slave, 1=write to slave
b0=? 'data: not required for read mode
adres=? '0 to 1, 3, 7, 15, 31, 63, 127 or 255
' 1bit,2, 3, 4, 5, 6, 7, or 8bit
gosub sendvar0
sendvar0:
if rw=2 then
rw=0
elseif rw=3 then
rw=1
b5=b0
b6=adres
high iredout 'start signal
if iredin=0 then sendvar0
low iredout 'end of start signal
low iredout
for b3=1 to 2
for b2=1 to adresbits 'how many address bits there are
if iredin=1 then invcom
if ad0=1 then 'address
pulsout iredout,hitime
pulsout iredout,lotime
low iredout 'pause for short time
adres=adres/2
low iredout
low iredout
next b2
low iredout
if rw=1 then
pulsout iredout,hitime 'write bit
pulsout iredout,lotime 'read bit
if rw=2 then recvar
rw=2
goto readsk
pause 1
for b2=1 to 8
if bit0=1 then 'data
b0=b0/2
low iredout
low iredout
next b2
readsk:
pause 1
b0=b5
adres=b6
next b3
b0=b5
adres=b6
for b3=1 to 250
if iredin=1 then out1 'wait for ack
pause 1
next b3
goto sendvar0 'try again if ack not recieved.
invcom:
low iredout
for b2=1 to 10
pause 1
next b2
goto sendvar0
recvar:
adres=b6
for b3=1 to 2
b5=b0
b0=0
for b2=1 to 8
pulsin iredin1,1,plv 'data
if plv>midtime then
if plv>xhitime then invcom
bit7=1
elseif plv=0 then
goto invcom
if b2<8 then
b0=b0/2
next b2
next b3
pause 1
if b5<>b0 then sendvar0
if iredin=1 then sendvar0
out1:
symbol plv=w3 'variables
symbol adres=b1
symbol ad0=bit8
symbol ad1=bit9
symbol ad2=bit10
symbol ad3=bit11
symbol ad4=bit12
symbol ad5=bit13
symbol ad6=bit14
symbol ad7=bit15
symbol rw=b5
symbol iredin=pin0
symbol iredin1=0 'for pulsin command, sane pin number as iredin
setfreq m8 'required for fast and reliable operation
setint %1,%1
interrupt:
for b4=1 to 15
if iredin=0 then fail
pause 1
next b4
b0=0
adres=0
rw=0
waitin1:
high iredout
if iredin=1 then waitin1
low iredout
vloop:
for b4=1 to adresbits'how many address bits there are
pulsin iredin1,1,plv'address
if plv>midtime then
if plv>xhitime then fail
ad3=1 'ad? where ?=adresbits-1
elseif plv=0 then
goto fail
if b4<4 then
adres=adres/2
next b4
pulsin iredin1,1,plv'r/w bit
if plv<midtime then
if plv=0 or rw=3 then fail
if rw=2 then
goto validate
rw=0
goto rvalid
elseif plv>xhitime then
goto fail
if rw=2 then fail
if rw<>3 then
rw=1
for b4=1 to 8
pulsin iredin1,1,plv'data
if plv>midtime then
bit7=1
elseif plv=0 then
goto fail
if b4<8 then
b0=b0/2
next b4
if rw=2 or rw=3 then validate
b2=b0
rvalid:
b3=adres 're-use the above to save space
adres=0
b0=0
rw=rw+2
goto vloop
validate:
if b3<>adres then fail
if rw=2 then readadres
if b2<>b0 then fail
pause 2
pulsout iredout,xhitime'ack
write adres,b2 'Write recieved data to EEPROM.
hi2cflag=1
fail:
out1:
setint %1,%1
'Any extra bits you would like to add to this sub-procedure
'(like you do with the 'setintflags'-hi2cflag interrupt)...
readadres:
for rw=1 to 2
read adres,b0 'Read from EEPROM at address variable.
for b4=1 to 8
if iredin=1 then fail
if bit0=1 then 'data LSB
b0=b0/2
low iredout
low iredout
next b4
next rw
goto out1
Create two infared picaxe circuits, both with an IR emitting diode, and an IR reciever. use 'x', 'x1' or 'x2' parts, as the other ones don't have enough program space.
- connect the IR recievers according to picaxe manual 2, the infrain command.
- connect the IR diodes with a 270-330 ohm (max. picaxe output current) resistor in series between a picaxe output, and 0V (gnd). check the diode is the right way round. make sure the the IR diode's beam and reciever's line of sight is parallel to each other, and place a baffle between both on the same board to prevent direct feedback. see the picture below.
- specify the pin numbers on the pin-labelling symbols of both programs.
- download the master program in one picaxe, and the slave program in another one.
- keep the picaxe with the master program connected to your computer, running PE's serial terminal set to 9600 baud.
main: 'start writing to slave
b0=45
adres=0
rw=1
gosub sendadr
gosub sendvar0
b0=90
adres=1
rw=1
gosub sendadr
gosub sendvar0
b0=142
adres=2
rw=1
gosub sendadr
gosub sendvar0
b0=63
adres=3
rw=1
gosub sendadr
gosub sendvar0
b0=2
adres=4
rw=1
gosub sendadr
gosub sendvar0
b0=98
adres=5
rw=1
gosub sendadr
gosub sendvar0
b0=76
adres=6
rw=1
gosub sendadr
gosub sendvar0
b0=12
adres=7
rw=1
gosub sendadr
gosub sendvar0
b0=241
adres=8
rw=1
gosub sendadr
gosub sendvar0
b0=121
adres=9
rw=1
gosub sendadr
gosub sendvar0
b0=34
adres=10
rw=1
gosub sendadr
gosub sendvar0
b0=222
adres=11
rw=1
gosub sendadr
gosub sendvar0
b0=7
adres=12
rw=1
gosub sendadr
gosub sendvar0
b0=51
adres=13
rw=1
gosub sendadr
gosub sendvar0
b0=186
adres=14
rw=1
gosub sendadr
gosub sendvar0
'start reading and validating from slave
adres=0
rw=0
gosub sendvar0
b12=45
gosub sendata
adres=1
rw=0
gosub sendvar0
b12=90
gosub sendata
adres=2
rw=0
gosub sendvar0
b12=142
gosub sendata
adres=3
rw=0
gosub sendvar0
b12=63
gosub sendata
adres=4
rw=0
gosub sendvar0
b12=2
gosub sendata
adres=5
rw=0
gosub sendvar0
b12=98
gosub sendata
adres=6
rw=0
gosub sendvar0
b12=76
gosub sendata
adres=7
rw=0
gosub sendvar0
b12=12
gosub sendata
adres=8
rw=0
gosub sendvar0
b12=241
gosub sendata
adres=9
rw=0
gosub sendvar0
b12=121
gosub sendata
adres=10
rw=0
gosub sendvar0
b12=34
gosub sendata
adres=11
rw=0
gosub sendvar0
b12=222
gosub sendata
adres=12
rw=0
gosub sendvar0
b12=7
gosub sendata
adres=13
rw=0
gosub sendvar0
b12=51
gosub sendata
adres=14
rw=0
gosub sendvar0
b12=186
gosub sendata
pins=0
wait 10
sendata:
sertxd (#adres,": send ",#b12,", rec ",#b0,13,10)
sendadr:
sertxd ("writeI2R: ",#adres,13,10)
Return
writeI2R: 0
writeI2R: 1
writeI2R: 2
writeI2R: 3
writeI2R: 4
writeI2R: 5
writeI2R: 6
writeI2R: 7
writeI2R: 8
writeI2R: 9
writeI2R: 10
writeI2R: 11
writeI2R: 12
writeI2R: 13
writeI2R: 14
0: send 45, rec 45
1: send 90, rec 90
2: send 142, rec 142
3: send 63, rec 63
4: send 2, rec 2
5: send 98, rec 98
6: send 76, rec 76
7: send 12, rec 12
8: send 241, rec 241
9: send 121, rec 121
10: send 34, rec 34
11: send 222, rec 222
12: send 7, rec 7
13: send 51, rec 51
14: send 186, rec 186
