I'm attempting to create an easy demonstration of the PICAXE, so I'm looking for as "straight forward" as possible.
I picked up a Reed Relay with the following specs:
Voltage 5VDC
Coil Resistance 250ohms
Contact rating 0.5 at 125VAC
Nominal Current 20mA
As I understand, the outputs of the PICAXE can handle anything directly up to 20mA. (Picaxe Beginners Check List: part2) Is it possible for simplicity's sake to connect this directly to the output pins using a 220ohm resistor for controlling other switched devices without frying my 18X?
Thanks
Jeff
Voltage 5VDC
Thanks
Jeff
