This is my first time on this forum and to the world of PICAXE. I have just purchased VSM and received my licence key and I am using Windows 7. When I follow the steps above I get an error message indicating the key file does not support this version of VSM or the file may be damaged. The version I downloaded is 7.4 SP2. Any help appreciated Thanks.To register your licence key in Windows 7 please ensure you run licence manager in administrator mode. To do this select
Start > All Programs > Revolution Education > PICAXE VSM
and right click on LICENCE MANAGER and select 'Run As Administrator'
Here is the error message again. Hope this helpsWe couldn't see the image you posted - it's on your hard drive!
I am still having trouble restigering the VSM software. So far I have....We have tested the licence file and it is ok (see attachment), so we can only assume there is an issue with the way you are saving it from your email attachment to the hard drive or that you have some security software blocking access to it.
I opened the Licence.LXK file in Notepad and removed the space at the beginning of the text and saved the file.I am still having trouble restigering the VSM software. So far I have....
- Uninstalled VSM
- Turned off my Antivirus software (exited Kaspersky)
- Downloaded the latest version of VSM (see image)
- Installed latest version of VSM
- "Saved as" the licence key to the "Revolution Education" folder.
- Ran the licence manager - Licence Key not recoginised, same message as mentioned in an earlier post
- Turned on Ka
If the licence key has worked in the past for you is it possible my copy may be corrupted? If so could you please resend or suggest another possible soultion as I am really keen to start using VSM.
