chopperwalker
I haven't found this in the forum so I have to ask. I have two different microcontrollers that I want to control one relay with. It's a redundant system and (ideally) they won't operate at the same time. One is a 20x2 the other is a Picaso (uLCD-32PT) from 4D labs. The picaxe operates as a manual control of system in a panel. The picaso touchscreen is an automated system controller. The purposed of the setup is to allow manual operation until the touchscreen controller is totally debugged and in case the touchscreen is ever damaged (operating in a hot, wet environment with drunk people).
I need both to operate a reed relay. Do I need diodes to protect from the opposing outputs? What's the safest way to set this up?
Thanks in advance
Thanks in advance
