I'm thinking use one Xbee module with this battery:
http://www.sparkfun.com/commerce/product_info.php?products_id=8818
The problem is that Xbee module only works with 2.8 – 3.4VDC (http://www.digi.com/products/wireless/zigbee-mesh/xbee-digimesh-2-4.jsp#specs)
To drop down from 3.7v to 3.0 I can use a Diode, but I'm wondering: the battery will discharging continuously to 3.6v, 3.5v, 3.4v (...) 3.0v (http://www.sparkfun.com/datasheets/Batteries/Coin_Cell_Battery-PD2450.pdf) so at 3.0v I will have 2.3v (because I'm using the diode) and in this way I will not be able to use all the battery capacity
I'm not be able to use a voltage Regulator (http://www.sparkfun.com/commerce/product_info.php?products_id=595) because to have 3.3v VOut I need to have >4,8 VIn right? (that what is represented in this datasheet: 4.8V<=VIN<=10.3V)
So... what are my options?
