I have found that using a temperature sensor connected to C.6 (20M2) and trying to do a ReadTemp on this input causes the following error message - Ërror download failed Pin C.6 cannot be used for this command".
The simulator can be used without a problem with C.6 but download fails if you try to load a simple program into a 20M2. Is this a limitation of the 20M2 or a Logicator/compiler problem? I have worked around this issue by using C.0 for the temperature sensor.
