RonHackett
In a previous thread (READINTERNALTEMP RAW clarification needed, Started by premelec, 05-12-2011), Hippy wrote "The IT_5V0 and other options apply an appropriate equation which converts the raw temperature reading to an approximate temperature for a specific voltage and an offset can be applied as part of those commands."
I'm using an 08M2 breadboard circuit with a +5V supply, and a DS18B20 so that I can compare the internal and external temperature readings. Using this setup, I have determined the necessary offset parameter that results in equal internal and external temperature readings at a room temperature of +23 degrees C.
I would like to be able to use the circuit (without the DS18B20) to monitor the temperature of a shed during winter, especially if the temp drops below 0 degrees C. My question relates to the format of the temperature value returned by the readinternaltemp command. Is it the same format that's used in the readtemp variable? In other words, is bit7 of the value set to 1 whenever the temperature is below 0 degrees C? If not, how are negative values represented? Thanks...
