fastgrandad
I want to use the 18M2 hardware latch and to be able to read the SRQ status (0 or 1) from the program. All attempts have so far failed, e.g. using let b1=pinC.3 etc. I could connect the SRQ to a spare input pin and read it that way but I'd rather do it from the software if possible, not least as it would be good to be able check it all out in the simulator. The simulator currently shows the status of pin C.3 changing as the latch is set/reset but not any variable assigned to it. Is this possible?
