Jeremy Leach
I'm working on a little maths utility that 'might' be able to help with PID - not sure yet...
#PICAXE28X2
high B.5
high B.4
hi2csetup i2cmaster,%00110011,i2cslow,i2cbyte
main: 'hi2cout 0,(0x80)
'hi2cin %00000011,(b2)
'hi2cin %00000010,(b3)
'hi2cout %00110010,(%00110011)
'hi2cin (b2)
hi2cin 3,(b2)
hi2cin 2,(b3)
'hi2cin %10000010,(b1)
'hi2cin %10000100,(b2)
let bit0 = bit20
let bit1 = bit21
let bit2 = bit22
let bit3 = bit23
let bit4 = bit24
let bit5 = bit25
let bit6 = bit26
let bit7 = bit27
let bit8 = bit28
let bit9 = bit29
let bit10 = bit30
let bit11 = bit31
sertxd (#w0,",")
'sertxd (#b1,",")
'sertxd (#b2,",")
'debug
hi2csetup i2cmaster,%00011011,i2cslow,i2cbyte
hi2csetup i2cmaster,%0001101,i2cslow,i2cbyte
(without the last digit of the slave address)
#PICAXE28X2
high B.5
high B.4
hi2csetup i2cmaster,%00011001,i2cslow,i2cbyte
'hi2cin (b2)
hi2cin 3,(b2)
hi2cin 2,(b3)
let bit0 = bit20
let bit1 = bit21
let bit2 = bit22
let bit3 = bit23
let bit4 = bit24
let bit5 = bit25
let bit6 = bit26
let bit7 = bit27
let bit8 = bit28
let bit9 = bit29
let bit10 = bit30
let bit11 = bit31
sertxd (#w0,",")
'sertxd (#b1,",")
'sertxd (#b2,",")
'debug
No idea if this will work but its worth a shot.I'll see if I can find some faster software, but the 44100 might be the limmit of the hardware.
#PICAXE28X2
high B.5
high B.4
setfreq m1
i2cslave %1010000,255,i2cword
main: writei2c 1,(13)
pause 50
readi2c 1,(b0)
sertxd (#b0,",")
...that is cool.Bingo ! That does look like an I2C header ...
Start bit (S), SDA goes low followed by SCL going low
7 x I2C address bits, SCL pulses high
Write/Read bit (W=0/R=1), SCL pulses high
Ack/Nak bit (A=0/N=1), SCL pulses high
Stop bit (P), SDA goes high followed by SCL going high
So, that's "S0101000WNP", and that's a NAK because the 7-bit I2C address is 0101000 when it should be 1010000 for Eeprom.
Change to "I2cSlave %10100000,255,i2cword" and you should get "S1010000WA..."
#PICAXE28X2
high B.5
high B.4
setfreq m1
i2cslave %10100000,255,i2cword
let b1 = 0
main: inc b1
writei2c 1,(b1)
pause 50
readi2c 1,(b0)
sertxd (#b0,",",#b1,",")
Master: S0011001W 00000011 S0011001R NAP
Slave: A A AXXXXXXXX
Master: S0011001W ??P
Slave: A
#PICAXE28X2
high B.5
high B.4
setfreq m1
i2cslave %00110010,255,i2cbyte
let b1 = 0
SERTXD("RESET")
main: pause 50
readi2c 3,(b0)
sertxd (#b0,",")
