You need to be a bit more descriptive. What is it for and what will trigger its generation.need to set up a random time delay of between 3 to 30 minutes
I'm not at school for another week@Briski - which part are you stuck on? Don't forget you can also ask your teacher.
Sorry to be a bit of a pain, but I don't really get how to use the compare functionLook at the Random and Compare (If) commands in Logicator help. Basically, what you can do is use Random to generate a number and use Compares to check that the generated variable is within the limits you want, and if not, generate the number again until it is.
Within Logicator, clicking on the Help menu option will lead you to detailed information on each command. Particularly useful are -Sorry to be a bit of a pain, but I don't really get how to use the compare function
So how would the compare command work with the random command?Within Logicator, clicking on the Help menu option will lead you to detailed information on each command. Particularly useful are -
Help -> Contents
Help -> Manuals -> Logicator Manual
