; Damon Hart-Davis licenses this file to you
; under the Apache Licence, Version 2.0 (the "Licence");
; you may not use this file except in compliance
; with the Licence. You may obtain a copy of the Licence at
; http://www.apache.org/licenses/LICENSE-2.0
; Unless required by applicable law or agreed to in writing,
; software distributed under the Licence is distributed on an
; "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY
; KIND, either express or implied. See the Licence for the
; specific language governing permissions and limitations
; under the Licence.
; Author(s) / Copyright (c): Damon Hart-Davis 2013
; Flashing 7 LEDs, a red/green bi-colour in the centre; 6 surrounding it in a circle.
; Bi-colour LED between B.3 and B.6 outputs (via 330R+).
; All other B.0 to B.7 outputs driving LEDs (connected to ground via 330R+) in clockwise order around the circle.
#picaxe 18m2 ; 18M2+ device.
#no_data ; Not using the EEPROM.
dirsB = %11111111 ; All outputs.
symbol LED_BI1_RED_C = B.3 ; Bi-colour LED red cathode (short leg), green anode.
symbol LED_BI1_RED_A = B.6 ; Bi-colour LED red anode (long leg), green cathode.
; C.0: LDR light sensor (ADC input); higher voltage indicates more ambient light.
; Should be pulled low externally whether LDR used or not, so can be left as input or set to low output.
; LDR is ~1M dark resistance to V+, being pulled to 0V by a 10k--100k resistor.
symbol INPUT_LDR = C.0
; Light level (0 is dark, 255 is light).
symbol ambientLighting = B24
readadc INPUT_LDR, ambientLighting ; Take initial reading.
#rem
testPWM:
pinsB = $ff ; Everything on.
gosub centreRedSet
gosub pauseAndPWMLeds1s
toggle LED_BI1_RED_C, LED_BI1_RED_A
goto testPWM
#endrem
; Speed (and possibly brightness) settings.
symbol MAX_SPEED = 4
symbol MIN_SPEED = 0
symbol speed = B25 ; 0 is slowest (can be used with nap).
symbol randWord = W13 ; Random number store
symbol randB1 = B26
symbol randB2 = B27
; Initialise with bits from the internal temperature sensor.
readinternaltemp IT_RAW_L, 0, randWord
; Warm up with some spins...
for speed = MIN_SPEED to MAX_SPEED
gosub spinCW
gosub spinCW
gosub spinCCW
gosub spinCCW
next
sleep 1
mainloop:
W0 = ambientLighting * MAX_SPEED / 255
speed = W0 ; Set basic activity speed...
; Maybe do some spinning...
do while randB1 >= $40 ; 0 or more times, typically 2 or 3...
random randWord
if randB2 >= $80 then
gosub spinCW
gosub spinCCW
random randWord
; More likely to turn LEDs off and sleep here as ambient lighting falls.
if ambientLighting < randB1 then
pinsB = 0 ; All off...
sleep 1
B12 = 255 - ambientLighting min 1
; Do some flashing...
gosub briefRandomRound
; Sleep, longer when darker...
random randWord
do while ambientLighting < randB2 ; Guaranteed to terminate eventually, eg when randB2 == 0.
random randWord
sleep 1
; Flash just the centre light, briefly...
B2 = randB1 & 1
if B2 = 0 then : gosub centreGreenSet : else gosub centreRedSet : endif
nap 0
readadc INPUT_LDR, ambientLighting ; Re-check light level.
gosub reseed
goto mainloop
; Stir a little entropy into the pool!
reseed:
readinternaltemp IT_RAW_L, 0, W0
randWord = randWord ^ W0
random randWord
randWord = randWord ^ time
random randWord
; Pause for *nominally* 1s, matching LED output to ambient lighting.
; Destroys B11, B12, B13, B14, B15.
pauseAndPWMLeds1s:
B12 = 100
; Pause in B12 units of *nominally* 10ms, matching LED output to ambient lighting.
; Destroys B11, B13, B14, B15.
pauseAndPWMLeds:
B11 = pinsB ; Capture extant LED state.
; Software PWM on nominal 10ms cycle.
B14 = ambientLighting / 25 min 1 max 10 ; On time: never 0.
B15 = 10 - B14 min 1; Off time: nominally can be zero (for max brightness).
for B13 = 1 to B12
; Aim for LED duty cycle to go down with the ambient light level.
pause B14
pinsB = 0 ; Turn all LEDs off.
pause B15
pinsB = B11 ; Restore state of LEDs.
next
; Pauses in inverse proportion to speed and may adjust brightness of LEDs to match (software PWM).
; Attempts to conserve energy too.
; Destroys B10, B11, B12, B13, B14, B15
pauseToMatchSpeed:
B10 = MAX_SPEED - speed ; B10 is pause time on 'nap' (log) scale.
B12 = 2
if B10 > 0 then : for B13 = 1 to B10 : B12 = B12 + B12 : next : endif ; B12 is pause time on (linear) scale.
; Spin clockwise at specified speed.
spinCW:
pinsB = 0; All off...
gosub centreRedSet
high B.0
gosub pauseToMatchSpeed
high B.1
low B.0
high B.2
low B.1
high B.4
low B.2
high B.5
low B.4
high B.7
low B.5
low B.7
; Spin counter-clockwise at specified speed.
spinCCW:
high B.7
high B.5
low B.7
high B.4
low B.5
high B.2
low B.4
high B.1
low B.2
high B.0
low B.1
low B.0
; Do brief round of random flashing at current speed, with fewer and dimmer LEDs on with lower ambient lighting.
; Destroys B0 and others.
briefRandomRound:
random randWord
B1 = randB2 & $1f
B0 = ambientLighting / 4 + B1 min 15 ; 15 to 94 rounds depending in part on light levels...
do while B0 > 0
dec B0
gosub allRandomSet
if ambientLighting < $80 then
random randWord
pinsB = pinsB & randB1 ; For low light knock out about half the LEDs.
if ambientLighting < $20 then
pinsB = pinsB & time ; For very low light knock out about half of the remaining LEDs.
; Randomise all the LED states, as normal (B) outputs, using randB2.
allRandomSet:
random randWord
pinsB = randB2
; Turn the centre LED red.
centreRedSet:
low LED_BI1_RED_C
high LED_BI1_RED_A
; Turn the centre LED green.
centreGreenSet:
high LED_BI1_RED_C
low LED_BI1_RED_A
