puddlehaven
For my birthday this year my wife got me a Spare Time Gizmos ELF 2000 kit, a re-interpretation of the original 1802-based computer that I (and many others) built from plans in Popular Electronics.
Just like the first one that I built, this one had a few problems when I first turned it on. Finding and fixing a bad connection in an IDC socket was fairly easy, and I found the cold solder joint on the switch panel after just a little more work. What was harder was the fact that some memory locations just didn't seem to be changing, and I couldn't figure out why.
So I built a test rig for the 32K static RAM on the ELF2K. I used a Picaxe 40X1 as the brains, two 74HC595 chips to latch the 15-bit address required, and a handful of LEDs to show me what's going on.
I used PortC to read and write data to the RAM chip. I had some difficulty getting the bi-directional data bus to work until I put "dirs=" statements in the code to explicitly change from output to input when writing then reading the test data.
Since PortC was in use, I couldn't use the hardware SPI port, so I used the simple bit-banged serial protocol from the manual.
Once I had the test rig up and running it started indicating memory errors throughout the RAM chip, but especially on the last page of memory, the page that the ELF2K uses for it's system data page, and where the OS on the ELF2K was indicating there was a problem.
I've ordered a couple more RAM chips that should be here tomorrow. Once I've got a known good RAM chip to install in the ELF2K I'll be one step closer to getting it to work.
I've attached a picture of the test rig on my breadboard, and the code for the test harness follows.
EEPROM (0xFFFF, 0x0000, 0xAAAA, 0x5555)
SYMBOL SER = 0
SYMBOL RCK = 1
SYMBOL SCK = 2
SYMBOL OE = 3
SYMBOL WE = 4
SYMBOL runningLED = 7
SYMBOL errorLED = 6
SYMBOL pulseLED = 5
SYMBOL varOut = W0
SYMBOL curAddress = W1
SYMBOL hiBit = Bit15
SYMBOL counter = B13
SYMBOL bits = 16
SYMBOL testLoc = B12
SYMBOL testPattern = B11
SYMBOL testData = B10
PowerOnReset:
LOW SER ' Serial data
LOW RCK ' Register clock
LOW SCK ' Serial clock
HIGH WE ' RAM Write enable
HIGH OE ' RAM Read enable
PAUSE 2000
HIGH runningLED
SERTXD ("Starting test",13,10)
curAddress = 0x0000
MainLoop:
' Loop to test each address.
FOR curAddress = 0x7FFF TO 0 STEP -1
'SERTXD("[",#curAddress,"] ")
FOR testLoc = 0 TO 3
' Get test pattern from EEPROM
READ testLoc,testPattern
varOut = curAddress
'testPattern = B2
GOSUB SendDataToLatch
' Set test pattern on output.
dirsc = %11111111
portc = testPattern
'SERTXD (#testPattern)
' Write to RAM
LOW WE
HIGH WE
' Read data from RAM
dirsc = %00000000
LOW OE
READPORTC testData
'SERTXD (" : ", #testData," / ")
HIGH OE
' Test the memory location
IF testData <> testPattern THEN
HIGH errorLED
SERTXD ("[",#testPattern,"] Address: ",#curAddress," Read: ",#testData,13,10)
PAUSE 10000
LOW errorLED
'END
ENDIF
TOGGLE pulseLED
NEXT testLoc
'SERTXD (13,10)
NEXT curAddress
GOTO MainLoop
SendDataToLatch:
FOR counter = 1 TO bits
IF hiBit = 0 THEN
LOW SER
ELSE
HIGH SER
ENDIF
HIGH SCK
LOW SCK
varOut = varOut * 2
NEXT counter
HIGH RCK
LOW RCK
RETURN
