hi all
i need help
i can't find the solution
i built a radiocommand set using a 40x2 3.3v for the sender and another one for receiver
the problem i encountered is strong jitter on servomotors
the emitter scans four potentiometers using adc commands ,resize the mesurments,and send them via an xbee module to the receiver which
receipt each channel and dispatch the good value to the good servo
it works but there much jitter i can't kill
reading manual2 it seems (it is what i undersand)that the serin command is the cause of the jitter because it have priority over the servo command
the emitter use readadc command and a serout command
whilst the receiver use a serin command with qualifier system and (servo fot init first time) servopos each time data is received
some good idea for a solution?
thanks by advance
i need help
thanks by advance
