Ive been searching for a simple answer to this but havent had any luck so far. If I run a signal line, say from an 08m on one end to a ULN2003, through a single stranded 24awg wire could I get 25' out of it from one end to another? In this example Id only be using the toggle command but later I may want to use similar wire for serial comms or pwm.
I did find a chart that had 24awg wire at 25.67 ohms per 1000 feet of wire. Divide that down to 25' and thats about .8 ohms. That <i>shouldnt </i> be enough to block the signal should it?
Any thoughts?
Brian
Any thoughts?
Brian
