quick question on letpins and simulator
hax
I have a seemingly simple program that doesn't work in the simulator:
let pinsb=%11111111
let pinsb=%00000000
I would expect the b.0 to b.7 pins to go green but they don't. Individual pins can be addressed no problem however. It's my first time using the simulator. What am I doing wrong?
erco
I forget, with Picaxe do you need to specify the pins as outputs before using pinsb? Using either output or.dirs command. Or was that BASIC Stamp...?
Also try outpinsb, that may be sufficient.
marks
erco beat me
dirsb=%11111111 ' set portb pins as outputs
pinsb=%11111110
SERTXD (CR, LF, #pinsb)
b0=pinsb : SERTXD (" %",#bit7,#bit6,#bit5,#bit4,#bit3,#bit2,#bit1,#bit0)
let pinsb=%00000000
SERTXD (" ",#pinsb)
