Is there any good reason for duplicating the programming resistors and diode on every project? Is there any disadvantage to just mounting the resistors on my DB9 connector, then using a 3 pin header to program the board?
Seems that's the only way I see it being done, but it seems like wasted effort.
The input pin still needs a pull down resistor, but 100K seems to work fine and doesn't really affect the programming signal.
Another question ... what is the purpose of the 180 ohm resistor on the output pin? I'm assuming its there to limit current. Why? The reved stereo jack program cable shorts it when plugging and unplugging?
