Hey Fellas,
I'm trying to get some LEDs to work with a experimental home made board,
I'm using a 18X1, when its installed on the axe090 board with a simple code the LEDs do what they are supposed to do.
But when I place the pic on my home made breadboard it will not.
this is how I have it connected: output pin to resistor(300R) to led to Ground
I'm thinking the problem might be the resistor.
Its 1/2 watt, it seems bigger then the ones provided by the axe090.
Can I use 1/4 watt or is there an standard to be used by the 18x1?
Thanks.
Thanks.
