Again I'm trying to do the unnatural! I use essentially Hippys 4bit LCD routines on pins B.2 to B.7 on the 20M2. Works well.
There is a note in the archive that explains how to use B.0 and B.1 as outputs at the same time.
However I would like to use B.1 as a PWM output in the same application.
This Read/Modify/Write doesn't work as it seems that writing to PinsB converts B.1 back into a simple output, shutting PWM off.
PortC is already in use.
Before I spend anymore time on this - can it be done?
I've used this method for simple outputs, again works well.A problem which may occur with the use of the above routines is when Output Pins 0 or 1 are used within your program. Because of the use of the 'pins =' assignments, these two bits are always set low whenever the 'SendCmdByte:' or 'SendDataByte:' routines are called.
If it is not desirable to have these two bits cleared while interacting with the LCD, the routines can be modified as follows ...
