Pwm Controller..???
cdstang1986
Can you use a picaxe 08m or 14m to make a PWM fan controller..
(PWM)=Pulse-width modulation
Here is a link to a PWM that uses a 555n Timer
LINK PWM
Any help would be great..
Thanks
boriz
"Can you use a picaxe 08m or 14m to make a PWM fan controller.."
Who, me? Sure. But then I have read the manual. :)
Seriously though, this is a breeze with Picaxe. All you need to know is in the docs. Read that first, then come back here if you have any problems.
premelec
Note the PWMOUT command which will run continuously on one pin whilst doing other stuff with the PICAXE.... very helpful!
A Forum Search from the top menu bar of this page should find other PICAXE fan control projects. For short search terms add a *, so for PWM use PWM*
Dave-nz2
Short answer: yes.
I see you have made a start, and found a pwm fan controller circuit.
See picaxe_manual2.pdf for pwm & pwmout commands, and note the pin used, the command format, etc...
Hint: *Always* search the 3 picaxe manuals first.
See picaxe_manual3.pdf - see "Output Devices 5 - Solar & DC “Toy” Motors" (not that it's much)
(I downloaded the latest manuals just for this search, and looked hard, and found fa myself)
Hint: Tell the forum what attempts you have made. Forum is more for correcting than doing *smile*
A similar random circuit to the one you found: http://www.discovercircuits.com/DJ-Circuits/images/SIMPLEPWM2.jpg
(from page http://www.whatcircuits.com/motor-control-circuits/555-timer-forms-simple-pwm-motor-controller/ )
Look at lots of simple small motor pwm control circuits, they're common for other micros too, so many of the circuits for, say, the basic stamp, will be a good start for use with the picaxe. Google is your friend.
Looking at search results will help you refine your search terms within the forum, and elsewhere.
On Stans site: http://picaxe.orconhosting.net.nz/
Look for his May 2003 Silicon Chip article offering (worth starting with)
"May - Motor controller /motorpwm.bas"
Would a (polytech) library perhaps have that issue around where you are?
The following link is a fan control project that only turns fan on or off depending on temperature, but gives an idea of the next step in completing your design.
http://www.picaxe.us/AV-fan.html (Cct: http://www.picaxe.us/images/AV-fan-small.png )
Oh, and another circuit, as an example of a fully worked-out design.
http://www.siliconchip.com.au/cms/A_111001/article.html - 12V Speed Controller/Lamp Dimmer
Hope these are of some use to help you move forward.
A common difficulty is knowing which of many directions to answer in, which requires more info from you.
Q: Is there a particular fan you want to control? (Important for suitable circuit design) Or is any small fan a good start for you?
Q: What is your overall goal? Is it educational, or a particular task you have in mind? May I stress that You need the forum to know this.
Your turn :)
