Using the circuits from the manuals I’m trying to get an 08M to drive an IR LED using the command pwmout 2, 25, 53. When I use infraout 1, 55 the receiver works perfectly and triggers another Picaxe (later I want to get a single 08M to do both jobs). When I use the PWM command the receiver only sees the periphery of the LED output field and it’s output signal while still 5 volts is scrambled, any ideas anyone?
