OK...I know you put a diode across a relay to keep it from breaking the Picaxe chip when it turns off.
Now...I'm working on RF camera with video controller, and I need to share the audio channel on the RF transmitter. I intend to have the cameras audio and the tone, used to control my VCR controller, going through the same pipe....so to speak. I'll send a tone with Picaxe, but the camera's audio will be there too. That should be OK I suspect, but the tone will only be needed a few seconds, then....well...then the cameras audio will be putting audio into the Picaxe output pin. Can't use a diode here, so is this a problem?
I'd use a DPDT relay to separate them if I had more output pins...might need another chip huh??? orrrrrrr...can I get away with it???
