I'm using the following piece of code in a program
And it works fine.
I've started experimenting with the pulsout command and found that if I add the following line of code
it seems to pass the syntax test but does not work when transfred to an axe.
But if I leave the pins= or pinsc= command in the program, the syntax test fails.
All of which is a long winded way of asking "is it possible to use the pulsout function with a pins=%00000000 instruction, so all the outputs can be made to flash on/off" ?. I can't find any reference in the manuals to this.
route1:
gosub sub1
let pins =%10000000
let pinsc=%01000001
goto start
pulsout %10000000,500
