Well, it's good to be able to be back on this project, after such a long break.
That said, eurgh it's going badly.
Just a quick recap of what it is. I've got an RC tank, which I currently can't use because I need to be on 27 or 72Mhz (or possible 2.4Ghz) but am currently trying to make the gun elevation stay in one place while the tank pitches back and forth, and get the turret to stay at a particular angle while the tank moves around. I have been trying to use gyro's for this but this may not be a feasible option...
I recently bought another gyro on the basis that the first was in bit and that there was a possibility that it was knackered, I would also need two anyway. I tested the new one by attaching it (securely) to the servo horn then trying to adjust it so that I can move the servo, but the horn and gyro stay put.
I've had limited success. The gyro stays roughly at the same angle, but it is constantly oscillating when left in a positions; I just can't stop it "shivering". I think the reason behind this, is that the damn thing was plainly designed for a helicopter. A little bit of oscillation in the speed of the tail rotor won't matter as long as it is reasonably high frequency (which it is, about 6 per second) and regular (which it is). However, for my gun barrel, it would be ridiculous, and it would leave the drive for the turret rotation utterly knackered.
To conclude, I don't think an ordinary gyro will do for the gun elevation. I think and accelerometer is the best bet there, and I'm not even sure the turret rotation is going to be possible.
That would certainly need a gyro of some sort; something like
this maybe (but If anyone knows of anything closer to the UK)?
Thanks,
David.
