Hi
I am using pulsin on an 18x to read an x-band motion sensor (www.parallax.com), it works fine at normal clock speeds, but when I underclock the chip, the program does not run properly, that is, it constantly resets the chip. The underclocking works fine if I comment out the pulsin line, and the program runs fine at 4Mhz.
Is there a problem with underclocking and the pulsin command?
Martin
Martin
