Pulse stops the parallel subprogram
Gapak
Hello, I also posted this entry on the French version.
I find that a pulse generated in the main program using the "pulse out" command interrupts the running of the subprogram ( start 1) during the duration of the pulse.
Is it normal or am I doing something wrong?
When I replace the "pulse out" command by a classic "output on" then "wait" then "output off" the subprogram is not affected.
I use a 20M2 and program with Logicator.
Thanks for your help.
Gapak
