What is the best way to measure the time between 2 pulses, one each on an input? The pulse pair repetition rate is about 80Hz., with the time between pulses from near 0ms to near 12.5ms. The output would be a 20 - 30 Hz PWM proportional to the time between input pulses. For best response, the input measurement and output PWM must run concurrently. Also would like to use the smallest PICAXE possible.
Any discussion and suggestions appreciated.
