Proto Board to Breadboard trick
Hello there! This is kind of my first project. Well I used to have a 08 proto board whitch i actually connect many wires to it so i could use it on a bread board. This went well but I am just showing off and giving people idea on a new way of going around this.
Here is how I had to solder it because there was actually cuts in the PCB. This was quite scary but I managed to get through it with out bridging a connection. :)
http://i53.tinypic.com/wvq3bc.jpg
And here is the other side on how I connect it the breadboard.
http://i53.tinypic.com/10gbpqa.jpg
I bought this all from rapid and to do this only requires the proto board some connectors(3p!) and to snip one off. And of course your trusty soldering iron ;)
I have also been working on some circuits, I am making slow progress but I am really confident :) Thanks for viewing and I hope I have helped some of you!
P.S You don't have to actually solder all the strips because the two outer tracks are all connected! :)
Hello Trevor,
While it may be a personal preference, it would be good if you could attach your images directly to your post here rather than links to another website.
The reason is that for all the good intentions, links do get broken and when this happens a lot of useful information can be list lost.
Yes Nick,
Lost (not list).
A problem with using my iphone for forum access while travelling (I am not driving) where I find with a combination of small screen, small key areas and it's idea of what is the correct spelling but . . . . c'est la vie.
