dennis shubert
I have a 28 project board 103g resistor array picaxe 20-1 the board ahas a 9 pin a 10 k pull down reesistor array installed on inputs c0 thru 7 as a minimum operating circuit. I want to use the sda-scl-hi2c on pins c.3 and 4 BUT I will need pull up resistors on these lines not pull down. Data sheet states that to use these pins for i2c etc.. the resistor would have to be removed. My de-sauldering tool does not work very well or at all on these small pins, it heats and (sucks) but don't want to heat board too much. So QUESTION can I just wiggle back and forth and remove the resistor and then incorporate the pull down resistor in my other circuit design. OR would prefer to just take a pair of snips and just cut it in half between r-4 and 5 leaving 5-6-7 pulled down for input pins and pins 0-4 floating. I qwould like to use the 28 board for master and other picaxe ic as a slave and use cL126... eproms, but i need sda scl etc... any help or suggestion would be appreciated answer here or
Address removed by eclectic
I just set this account up, hope I am posting in the correct palce. Thanks in advance. Dennis
