Andrew Cowan
Any M2, X, X1 or X2 PICAXE is capable of i2Cfast (so 400kHz).
Well that's certainly a good basis on which to proceed.I believe it's possible
I too would have reservations ........Although I'm guilty of promoting these HopeRF transceiver modules some 3 years back,times have moved on & in any case I'd have significant reservations about using them in demanding applications.
Well .. I have spent a while wandering around the woods in the local park, using a simple decreasing power rising frequency beacon and a cheap UHF receiver , you can get to within 5M or so of where the beacon is. When you get close just take the antenna off.At UHF a distance estimating woes may arise with signals bouncing all over the place and LOS view corridors (between trees etc) showing enhanced levels.
I wonder if we are at the point where GPS is small enough and light enough to control a plane? Head to a pre-programmed location (the launch site), do very slow turns, then head downwards in a square shaped flight path.When said plane is at an altiude of 1,500ft and 1,500ft out, you ought to consider what happens if you loose RC control and it flies away.
Its already done, albiet not with a PICAXE;I wonder if we are at the point where GPS is small enough and light enough to control a plane? Head to a pre-programmed location (the launch site), do very slow turns, then head downwards in a square shaped flight path.
I am not sure how all RC units "fail" as they go out of range, by my sailing yacht tends to send the servos right to one end of travel. So if a servo is jittering, or right at the end of travel, or maybe some other way is found to detect it is out of range, then a picaxe could take over and bring the plane back into range.
The input to the picaxe is a GPS, and the output is a range of servo signals. The algorithm is a little complex, but I don't think it would be beyond some of the newer picaxes.
Thoughts?
