SilentScreamer
I've got a reasonable collection of IC's and other electronic bits but I've got no idea what to make. I want to build a challenging project that will prove educational. I'm happy to spend as long as needed on it. I'm doing GCSE electronics (I haven't yet done the final exam however I got almost full marks on the mock exam), I have used LCD Displays and keypads before and I'm reasonably confident with visual basic. I also have the means to make PCBs. Below is a rough list of components that I have:
I've also got quite a lot of MAXIM ICs (a local company was throwing them away, a mate of mine was doing their work experience at the time and was given them). I've put what the all are into a excel spreadsheet (for the DIL components at least the surface mount chips can wait). The ones that stand out for me are the ADCs and DACs.
Any project ideas and useful links would be much appreciated, I don't mind how challenging they are (to a point of course ).
(The attachment needs its extension to be renamed to .xlsx)
- 2 Xbees (the standard one not Pro)
- Several 08Ms
- 2 28X2s (3V) (I have 2 16Mhz resonators to run these at 64Mhz)
- 2 28X2s (5V)
- 1 28X1
- 1 LCD Firmware Chip (rev-ed's)
- 2 3.3V LDO voltage regulators
- loads of 5V regulators
- Several 1F 5V caps (and some 10,000uF caps)
- Countless LEDs
- 16X2 LCD Display
- 10x RGB LEDs
- Loads of 500R 1K 5K and 10K 22 turn pots
- 5x Dual 7 segment displays and 5 single 7 segment displays
- Loads of PTM/PTB switches
- 16 pin DIL switch array (if thats what its called, its a 16 pin DIL package with 8 slide switches built in)
- Loads of caps and resistors
- This eprom IC - http://www.datasheetcatalog.org/datasheets2/14/147181_1.pdf
