Embarking on ambitious project, to me it is unclear if it can be done with a picaxe.
I want to make a 'pretty-accurate' Temperature probe/device based on the Analog Devices ADT7410. I need to read I2c register data in from it, and do some math conversion and Display temp on 7segment display in C.
I want to keep all of the temp data - so no rounding or truncation errors. I dont want to loose any resolution/accuracy -ie to use all of the typical accuracy of +/-0.1C from the chip.
The data from temp i.c. is in a two byte word, and 13bits of this are the binary temp.
25C is..... 0 0001 1001 0000 I need to make this Decimal and then divide by 16 for degrees Celcius.
Is there a picaxe that will be happy to pull this data and do the math functions well, so I get no loss in resolution in the temp chip data?
I dont know how to do the rest of it either, but this seems fundamental to me.
Golfnut
Golfnut
