Hi
I see using PICAXE Editor 6 there is a RTC wizard.
I was wondering how do I modify the code to add a alarm at 9am and 7pm seven days a week with using the output register INTCN and pin INT/SQW.
Also it is easy to use a 8M2 or 14M2 to load the program into the DS3231 and then remove the chip. so the DS3231 runs on its own and changes
outputs on the INT/SQW pin when the alarm conditions are met. DS3231 will be supplied with backup battery and 5v supply so it say programed once done.
Thanks for your help in advance.
