Hi Folks.
It's late here and I have been working on this all day so please forgive and glaring assumptions.
With a Picaxe 08M2 can one use the Serial In (pin c.5) for non programming serial
What I want to do is to use a 08M2 and program it normally, then put it in a circuit with a USB to Serial on pins C.0 and C.5 so that it can be updated with a normal terminal program.
For simplicty I am using the 08 Proto-board as the basis for this project
This is a simple example.. But when I connect the serial IN from the USB-TTL to C.5 the picaxe basically resets.
b1 =0
serin [100], c.5, T2400_4,#b2
serout c.0,T2400_4, (#b1," Hello ",#b2,13,10)
b1 = B1 + 1
if B1 > 100 then
b1 = 0
end if
