I am trying to make a large display of distance data from an ultrasonic detector connected to a PICAXE14m2. I'm having trouble figuring out how to connect the PICAXE14M2 running at 5v to two 4026B counter microprocessors and 2.3" 7-segment displays running at 7 volts (the large display uses 4 Red LEDs in series for each bar in the display, so it needs 7v). What I have done is put the 4026B and LCD display pairs on their own board and power them with 7v (the 4026B stats sheet I read says it can handle up to 20v). I have the PICAXE14M2 on an AXE117 wired to 5v supply and I have the clock and reset lines on ports B.1 and B.2 respectively. These two feed to the LCD board and connect into the clockin and reset lines on the first 4026B, as described in Chapter 3 of the PICAXE manual.
What I find is that after all is wired up, I get both 7-segment displays showing zero on power up. When I run the code on the PICAXE14M2, I only see intermittent weak flashes on the center horizontal bar (the only one not lit when the LCD is displaying "0"). I suspect that the 5v clock and reset signals may not be adequate to cause the 4026B's to operate the large LCD displays. Does this sound reasonable? If so, would boosting the clock and reset signals to 7v solve the problem? Further, if this is the solution, how would I best accomplish this on the AXE117 board?
I've attached a file showing how the LCD board is wired. At the top center of the diagram, you'll see a series of 7 pins, the top 5 of which take the external feeds from the AXE117 to control the signals. The bottom 3 of these 5 pins are meant the drive a couple of 3 led light boards (red, yellow and green), and the top two pins are the clock and reset inputs also coming from the AXE117 The bottom two pins of this 7 pin header are the 7v power lines.
Any ideas? Thanks!
Any ideas? Thanks!
