Problem with servo @16MHz
husslemk4
Hello,
I'm trying to run a servo with a 28X1 at 16MHz and I am having some trouble. When I run my code the servo jams itself fully to the left. Im using firmware A.2, so perhaps this problem was adressed in newer firmware. Any ideas would be great,
Thanks
setfreq em16
init:
high 6
pause 500
servo 5, 150
servopos 5, 150
pause 100
Latest firmware.txt does not indicate anything specific about servos at 16MHz not working with A.2 Firmware. Does the servo operate as exected at 4MHz ?
Thanks. We will have to investigate the issue. The workround at present would seem to be to run at 4MHz or run at 16MHz using a bit-banged servo loop. Untested but the following should hopefully work ...
#Picaxe 28X1
#No_Table
#No_Data
w0 = 150 ' Servo Position (75..225)
SetFreq EM16
w0 = w0 * 4
w1 = 8000 - w0
Do
Pause w1
PulsOut 5, w0
Loop
MartinM57
Obvious (probaby stupid) question - you did have an external 16MHz resonator fitted originally i.e. for post #1?
