I wonder if I could seek advice again. I am fairly inexperienced programming picaxe and am playing with a stepper motor, rotary encoder and display to move a camera on a linear rail to do some focus stacking. The stepper, encoder and display all work well the process is to input a number of steps for the stepper motor using the encoder then input a number of times to repeat the steps again using the encoder.
Between each batch of steps I want to pause and trigger the camera to take a shot then proceed to the next batch of steps. (gosub CAMERA)
I need an output from the chip to drive an opto isolator and at present just have an LED connected to B.5, I am expecting a flash each time the program pauses between batches of steps ie triggering the camera but instead I am getting an unusual sequence of flashes depending on how many steps and shots I request.
If I set 6 steps and 9 shots the led flashes on 1,3,5,7,9 shots
if I set 9 steps and 9 shots the led flashes on 2,3,6,7 shots
If I set 15 steps and 9 shots the led flashes on 1,2,5,6,9 shots
I have left the shots at 9 for some consistency anything different would give different results.
I am tearing my hair out on this one and due to limited knowledge have hit a brick wall.
I have included my code, I'm suspecting some problem with dirs or pins statements but not sure, any help would be much appreciated.
Jim
Jim
'ROTARY ENCODER READER AND STEPPER MOTOR CONTROLLER Picaxe 18M2
INSTRUCTIONS:
#Picaxe 18M2 ' specify the PICAXE the program code is for
#No_Data ' do not download data EEPROM values
Pause 500
MESSAGE:
setfreq M4
serout C.7,n2400,(254,128," FOCUS STACKER")
serout C.7,n2400,(254,192," XXXXXXXXX 2018")
Pause 5000
serout C.7,n2400,(254,1)
serout C.7,n2400,(254,128,"Each Step=0.04mm")
serout C.7,n2400,(254,192," Table Travel")
pause 5000
setfreq M32
let dirsC=%11001000 'set pin 3 & 7 as outputs
b10=0 b11=0 b2=0 'b10 = steps b11 = shots
gosub STEPREQUEST
gosub ENCODER
TEST1:
if b10>0 then 'test if STEPREQUEST is complete
b11=b1 'set b11 as no of shots
goto CHECKER endif
b10=b1 'set b10 as no of steps
if b10>0 then 'if STEPREQUEST is complete then perform TEST2
goto TEST2 endif
TEST2:
gosub SHOTREQUEST
gosub ENCODER
CHECKER: 'report steps and shots
setfreq M4
serout C.7,n2400,(254,128)
serout C.7,n2400,("Step ",#b10," Shot ",#b11)
serout C.7,n2400,(254,192,"Press to Start")
setfreq M32
gosub PUSHBUTTON1 'check for pushbutton enter
REPEAT: 'repeat sequence
w0=b10*40 'this bit converts steps to distance travelled
w0=w0/10
bintoascii w0,w1,w2,w3
gosub STEPPER
if pin0=0 then 'if encoder button pushed then repeat
goto repeat endif
end
STEPPER: setfreq M4
serout c.7,n2400,(254,128)
serout c.7,n2400,("TRAVEL = ",w1,".",w2,w3,"mm") 'travel distance report
setfreq M32
let dirsB=%00001111 'set output pin
for b4 = 1 to b11 'number of shots
for b3 = 1 to b10 'start a for...next loop
gosub lstep 'call left step sub-procedure
next b3 'next loop
pause 10000 'PAUSE BETWEEN SHOTS
gosub CAMERA
next b4
for b4 = 1 to b11 'return to start position
gosub rstep 'call right step sub-procedure
next b3 'next loop
next b4
setfreq M4
serout C.7,n2400,(254,128," Job Complete")
low 4
serout C.7,n2400,(254,192," Press to repeat")
setfreq M32
lstep: 'left step
High 4 'switch on 12v to stepper
let b1 = b1 + 1 'add 1 to variable b1
setfreq M4
serout c.7,n2400,(254,192,"Shot No ",#b4)
setfreq M32
gosub stepit 'do the step
rstep: 'step right
let b1 = b1 - 1 'subtract 1 from variable b1
setfreq M4
serout c.7,n2400,(254,192,"Return to Home")
setfreq M32
stepit: 'stepper motor control
let b1 = b1 & %00000011 'mask lower two bits of b1 -- resets b1 back to 0 after reaching 4
lookup b1,(%1010,%1001,%0101,%0110),b2 'lookup code into b2
let pinsB = b2 'output b2 onto control lines
STEPREQUEST:
setfreq M4
serout C.7,n2400,(254,128,"No of Steps ")
serout C.7,n2400,(254,192,"Press to enter")
setfreq M32
SHOTREQUEST:
setfreq M4
serout C.7,n2400,(254,128,"No of Shots ")
Setfreq M32
ENCODER:
b1=0
setfreq M32 'set clock frequency
'b1 is output counter
'c.1=clk
'c.2=DT
'C.1=0 and c.2=0 = b0=0
'C.1=1 and c.2=0 = b0=2
'C.1=0 and c.2=1 = b0=4
'C.1=1 and c.2=1 = b0=6
main: gosub read_c 'read the encoder
if b0=0 then main 'test rotation?
if b0=4 then goto CW 'start of a clockwise rotation
if b0=2 then goto CCW 'start of a counter clockwise rotation
CW: gosub read_c 'is rotation CW
If b0=4 then 'wait for more
goto CW
if b0=0 then main 'return if rotation reversed
six: gosub read_c 'read the encoder
if b0=6 then 'check if clockwise
goto six
if b0=4 then CW 'if reverse rotation then goto cw
deux: gosub read_c 'read the encoder
if b0=2 then 'check if clockwise
goto deux 'wait for more
if b0=6 then six 'if reverse rotation then goto six
goto CWT 'clockwise complet?
CWT: B1=b1+1 'increment b1 +1
gosub DISPLAY
'debug
CCW: gosub read_c 'rotation is clockwise
If b0=2 then 'wait for more
goto CCW
if b0=0 then main 'goto main if rotation reversed
six1: gosub read_c 'read the encoder
if b0=6 then 'check if counterclockwise
goto six1 'wait for more
if b0=2 then CCW 'if reverse rotation then goto ccw
deux1: gosub read_c 'read the encoder
if b0=4 then 'check if counteclockwise
goto deux1 'wait for more
if b0=6 then six1 'if reverse rotation then goto six1
goto CCWT 'counterclockwise complet?
CCWT: if b1=0 then fin 'if b1 = 0 then fin
B1=b1-1 'decrement b1-1
gosub DISPLAY
fin: 'debug
read_c: b0=pinsC 'reading pins c
b0=b0 & %00000110 'mask c1 & c2
gosub PUSHBUTTON
DISPLAY:
setfreq M4
serout C.7,n2400,(254,141," ")
serout C.7,n2400,(254,141,#b1) 'display encoder output
setfreq M32
PUSHBUTTON:
if pin0 = 0 then
pause 5000
goto test1
PUSHBUTTON1:
low b.0 low b.1 low b.2 low b.3 'Switch off data lines to stepper controller
if pin0 = 0 then exit 'check for pushbutton on end of encoder
loop while pin0>0 'loop until pressed
CAMERA:
High 5 'Trigger camera
pause 3000 'short wait
Low 5
Pause 1000
