Hello,
The PNS seems to work fine but I can't get the stuffs on the NET006 board work as expected. The temp. sensor reports a constant temp of -0,06°, when switching on the output LED, it flashes at regular intervals, the PWM LED also flashes, the LDR reports incorrect figures, the swich on pin 3 doesn't work (although the PNS mode switch on pin 7 works fine), etc...
I'm a bit annoyed that the PNS KIT that I purchased had obviously been used or repaired before ... So I wonder if it's a problem with the PNS.
Thanks in advance.
Thanks in advance.
