I am having a problem with the MIN function. When I set it to 2 and have a large stepsize on my dec routine below it rolls over to 65xxx.
Is this a bug or am i not using it correctly. This is happening in the sim and on the chip.
The way it fails is set input 2 until it maxes out at 5000 then release and set input 3 and let it run down. It happens only with a large stepsize.
<code><pre><font size=2 face='Courier'>
Symbol Frequency = W0
Symbol Stepsize = W1
Stepsize = 1
Frequency = 2
Main_Freq:
If pin2 = 1 then incfreq
if pin3 = 1 then decfreq
b4 = 0
goto Main_Freq
Incfreq:
gosub counts
pause 250
Frequency = Frequency+Stepsize Max 5000
goto Main_Freq
Decfreq:
gosub counts
pause 250
Frequency = Frequency-Stepsize Min 2
goto Main_Freq
counts:
b4 = b4 + 1
if B4>250 then resize
select case B4
case 1
Stepsize=1
case 11
Stepsize=10
case 20
Stepsize=100
case 30
Stepsize=1000
endselect
goto notresized
Resize:
B4=250
notresized:
</font></pre></code>
Stepsize = 1
Frequency = 2
Main_Freq:
b4 = 0
goto Main_Freq
Incfreq:
gosub counts
pause 250
goto Main_Freq
Decfreq:
gosub counts
pause 250
goto Main_Freq
counts:
b4 = b4 + 1
select case B4
case 1
Stepsize=1
case 11
Stepsize=10
case 20
Stepsize=100
case 30
Stepsize=1000
endselect
goto notresized
Resize:
B4=250
notresized:
