For some reason I am trouble with serrxd . The values I get are sometimes off by one bit or two ie. I may receive 12 instead of 140. I know the serial in and out line to the chip is ok. If I connect them together I echo values perfectly to my terminal. Here is my code. I'm using a 20X2
disconnect
serrxd b0
reconnect
sertxd (b0)
The chip programs ok. I'm sending b0 back out the serial port to see if the chip received it correctly. Even when I wasn't sending the data back out the serial pin on the 20X2 the data wasn't being received correctly. I have a decoupling cap at the chip and tried changing all inputs to outputs in case it was some noise acting on the inputs? Any ideas?
Thanks,
Jim
disconnect
serrxd b0
reconnect
sertxd (b0)
Thanks,
Jim
